Building a new ice install !!!
  • At this moment i\'m working on a new ice install, i didn\'t like the old JBL anymore..
    So now i\'m building a new custom ice install with all Kicker stuff.
    I already got a Sony MEX-R1 radio/mp3/wma/dvd unit in the front and a 7\" tft widescreen, that i custom made in the middleconsole.. that why the heatercontrols had to leave to another place !! :lol:
    This are my Kicker goodies, for the new install:
    Front:
    Kicker, ES-5.2 compo -> Installed!
    2-way 13cm car speakers (pair)
    CIMP woofer cone with Polyfoam surround
    PEN semi-dome tweeter
    power handling: 45 watts RMS
    peak power handling: 135 watts
    frequency response: 45-20,000 Hz
    sensitivity: 90 dB
    top-mount depth: 1-7/8\"
    Foto: ES 5.2 compo
    Rear:
    Kicker, ES-693 ovaal -> Got it!
    Size: 6 x 9
    Sensitivity: 92 dB
    Frequency Response: 30-21,000 Hz
    Recommended RMS Power: 70W
    Peak Power Handling: 140W
    Impedance: 4 ohms
    Foto: ES-693 ovaal
    Sub:
    Kicker, S12-L7 -> Got it!
    Rec. Sealed Box Dims: .88 - 2 cu.ft.
    Rec. Ported Box Dims: 1.75 - 3.25 cu.ft
    Free Air Usage: not recommended
    Sensitivity: 88.6 dB
    Frequency Response: 20-100 Hz
    Recommended RMS Power: 750W
    Peak Power Handling: 1500W
    Impedance: dual 4 ohms subwoofer wiring options
    Foto: S12 L7 sub (zilveren conus)
    Sub Amp:
    Kicker, ZX-550.2 -> Got it!
    Amplifier Type: 2-channel
    RMS Power @ 4 Ohms: 205W x 2 @ 14.4V
    THD at 4-Ohm RMS Power: <1 %
    Bridged RMS Power @ 4 Ohms: 550W x 1 @ 14.4V
    Speaker Level Inputs: yes
    Preamp Outputs: yes
    Built-In Crossovers: HP/LP
    Bass Boost: 0-18 dB
    Frequency Response: 20-20,000 Hz
    Signal to Noise Ratio: 95 dB
    Fuse Rating: 2 x 35 amps
    Foto: ZX 550.2 amp
    Powercap:
    Stealth, 1F -> Got it!
    24-karaats vergulde aansluitklemmen
    Vermogen 1 farad
    De powercondensator stabiliseert de aangelegde voedingsspanning voor uw eindversterkers. Dit voorkomt vermogensverlies door spanningsverval bij hoge vermogenseisen. Door een zeer geringe interne weerstand wordt een hoge vermogensafgifte mogelijk gemaakt. Door de 24-karaats vergulde aansluitklemmen kan het maximale vermogen met minimaal verlies worden overgedragen.
    Afm. (Øxh) 80 x 260 mm.
    Foto: STC-1000 powercap
    [Blockierte Grafik: http://www.kicker.com/06/downloads/buddyicons/BUDDY5.gif] [Blockierte Grafik: http://www.kicker.com/06/downloads/buddyicons/BUDDY3.gif] [Blockierte Grafik: http://www.kicker.com/06/downloads/buddyicons/BUDDY9.gif] [Blockierte Grafik: http://www.kicker.com/06/downloads/buddyicons/BUDDY11.gif] [Blockierte Grafik: http://www.kicker.com/06/downloads/buddyicons/BUDDY12.gif]
  • i still would not recommend to by everything from just one brand... only newbies do..
    some have good amps some have good speaker others have good x-overs and probably any other has the tweeters...
    and kicker... hm... just a brand.. not worse.. bud not best \'n any case..
    and a sony HU... jeah... ^^*sry* may happen they build usable things.. did not see any.. in carhifi.. well some swear on sony HU.. i would not..
    mfg da geith
